FPGA 2010 Compilation error - TclTasklC:project_028: Unknown property value
Hi, I'm using a cRIO 9075 and a NI 9211 to measure temperature for a project busy with. Everytime I try t compile code I have a compilation error that read as follows:
Compilation failed due to a Xilinx error.
Details:
ERROR: TclTasksC: project_028:Unknown property value "spartan6" specified for "PROP_DevFamily"
Can someone help me on how to resolve this error, I'm using LabVIEW FPGA 2010 and Xilinx 11.5
Regards
(3,622 Views)
What version of the NI-RIO driver do you have?
Attached is a chart with the different compatibilities of the RIO driver.
NI-RIO and LabVIEW Version Compatibility
https://www.ni.com/en/support/documentation/compatibility/17/ni-rio-and-labview-version-compatibilit...
Is this a 64-bit machine? Also, the minimum version of LabVIEW that will work with the 9075 is LabVIEW 2010SP1. You can verify if you have this version by going into Measurement & Austomation Explorer and expanding software. If you do not have LabVIEW 2010SP1, you will need either the platform DVDs for 2010 SP1 or you can download the content from www.NI.com/src.
You will also want to verify that you have the 2010SP1 FPGA module and 2010SP1 RT module.
Also, does this issue occur with all FPGA VIs that you try to compile or only the one that you are currently working on?
You can check by doing two things:
1. Try to compile a blank FPGA VI (i.e. nothing on the block diagram or front panel)
2. Try to compile an FPGA VI from one of the example LabVIEW projects
Please post back if one of these troubleshooting steps resolved your issue or if you're still having problems.
Jordan
(3,590 Views)
Hi, Jordan
Thanks for the reply and your advice. I upgraded to LabView 2011 and everything is working now
(3,579 Views)
Accepted by topic author luda0121
You're welcome! I'm happy to hear everything is working properly!
Happy Friday!
Jordan
(3,574 Views)
i have a similar issue with 2010 sp1.  I am on W7 64.  i have RIO 4.0 installed.
what next without updating to 2011?
Stu
(3,491 Views)
installing NI-RIO 4.1 fixed it but I am not sure why.
Stu
(3,487 Views)
