FPGA Cards
I am planning to use FPGA cards for my project. Could you please tell me what are the tools/software/driver required if i am using FPGA Cards(PCI/PXI)?
P.Surendar
(3,665 Views)
You would need LabVIEW and LabVIEW FPGA Module for sure. Are you planning to run on RT if you go the PXI route?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,661 Views)
Thanks Adnan.
I think we are going to use only PCI Cards.
If it is PXI we need to use additional Driver? Is it not required for PCI Cards?
P.Surendar
(3,657 Views)
If you were using a PXI controller, you have the option to boot into RT. If that was the case, then you would need the LabVIEW Real Time Module to develop applications so they can run on that OS.
Adnan Zafar
(3,649 Views)
Thanks Adnan...
(3,641 Views)
