closed loop control
pollon
(3,108 Views)
Hi all,I want to realize a closed loop measure and control. My goal is to control the speed of a pwm fan in base of the difference between two thermocouples: I start my VI I set the duty at 44% and then I want to check the difference: Tx-TyTx – Ty must always be = 0When Tx – Ty is < 0 I want to increase speed, if it’s > 0 I want to decrease to have always Tx-Ty = 0. Can anyone give me any suggestion.Thanks
pollon
(3,105 Views)
Accepted by topic author pollon
How do you control the Speed of the fan??
Do you adjust the pwm or do you have a control so you can set something like rpm?
Message Edited by Pattos on 10-13-2009 03:08 AM
Pattos
LabVIEW Gretchin
(3,104 Views)
