FPGA Crio encoder SSI protocol
Hello everyone
  Does anybody work with SSI protocol encoder and Crio FPGA? I wrote a simple program that try to implement this protocol on Crio FPGA, but i obtain chaotic data. I use a rs422-TTL converter to transform encoder signal (Rs422) to TTL signal for Digital high speed NI9401. Anyone could help me? any suggestion?
Thank you
francesco
Message 1 of 24
(7,962 Views)
Hi Francesco,
take a look to this link.
Bye
ANdrea
Message 2 of 24
(7,948 Views)
Thank you for your answer, Andrè.
I've not problem with signal conversion from rs422 to TTL, because i made it with electronic component who switch voltage level. My problem regards SSI protocol.
Message 3 of 24
(7,943 Views)
Accepted by FrankyCam
Hello everyone,
  I've solved my problem. I'm able to read angular position from an Eltra Encoder with SSI protocol using labview FPGA.
Thanks everyone for the help
Francesco
Message 4 of 24
(7,901 Views)
Can you post your solution. I was looking for something similar?
Message 5 of 24
(7,792 Views)
I've just modified an example on Labview site. Let me your mail in private message or in this forum so I'll send you my program.
Francesco
Message 6 of 24
(7,779 Views)
Can you provide a link to the example you modified? I am trying to work with SSI and a cRIO as well.
Abe
Message 7 of 24
(7,722 Views)
Could you please post the solution?
Thanks in advance.
Message 8 of 24
(5,965 Views)
Could you provide me the code or the example you found?
Thanks.
With regards, Seongbin
Message 9 of 24
(5,276 Views)
Hi dear,
Can you please share the solution?
Message 10 of 24
(2,266 Views)
