FPGA Digital output access of 30 different channel with a individual delay for each
I`ve an cRIO-9012 with NI9476 and NI9403. I need to control each single pin with an different time delay to turn ON/OFF. My suggestion of program is as image attached. But when we add for 30 different loop will that be compiled? Is it an good way to code an FPGA.
(2,482 Views)
If you wish to know whether it can comile, just duplicate it to 30 loops, and compile it. But if I were you, I'll use single cycle time loop, and counter for each line in shift register. Then, when counter hits a time limit, toggle the line and reset counter.
(2,473 Views)
Hi KateB,
             I couldn't`t simulate the counter hit the time interval. Can you portait one if you have time to spare on it.?
(2,470 Views)
