FPGA - Error -61023 on Windows XP running under user account
Thanks Steven!  I just realized that  your the same person I spoke to about a week ago on another issue.
LeRoy
Message 11 of 12
(677 Views)
LeRoy,
I did just check and noticed you were the same person I worked with too.  I had the chance to set up your system on one of my machines and was able to run a FPGA VI on an Administrator Account and also a limited account.  I tried several different Alias and they all seemed to work fine as well as not creating an alias as well and selecting the resource from a control box.  I did make sure that the FPGA vi and Host vi used was accessible in a shared folder.  If you select the Alias from a control box does it still give you the same error?
Steven B.
Message 12 of 12
(664 Views)
