FPGA I/O
Hi, Can you have two host sub VIs accessing an FPGA at the same time?  I would like to have one host sub VI read several U32 indicators on the FPGA VI front panel while a second host sub VI reads a boolean on the FPGA VI front panel.
My plan would be to wire the reference out of the Open FPGA Reference Function to two instances of the FPGA Read/Write control.
Do I need to synchronize these read operations or can they be asynchronous and possibly occur at the same time?
Neville
(1,661 Views)
Hi, Do you need to guard against two host sub VIs accessing the FPGA at the same time?  I would like to have one host sub VI read several U32 indicators on the FPGA VI while a second host sub VI reads a boolean on the FPGA VI.  Do I need to synchronize these operations or can they be asynchronous and possible occur at the same time.
Neville
(1,637 Views)
Accepted by nwild
Hi Neville,
you can access the same FPGA reference in several VIs at the same time!
Edit: Please don't spread the (basically) same question in several threads…
(1,632 Views)
