[FPGA] - NI 9401 - Input & Output Issues
Thank you! This was the solution to my issue. Got to be more careful on specifications next time Smiley Frustrated
Message 11 of 15
(1,278 Views)
Ok! Well maybe you can drive your external supply with the do using a relay without need of changing tour ni board. Bye. Marco
Message 12 of 15
(1,272 Views)
Or a simple digital buffer circuit often does the job as well.  How much current does the sensor need?
GCentral
Message 13 of 15
(1,266 Views)
It requires ~31 mA. How would you implement this as I have never worked with these things before.
Message 14 of 15
(1,257 Views)
Looks like something like a CD74AC244E should do the trick for you.  If you need help figuring out how to hook it up, I recommend you find an Electrical Engineer (or student) to help you.
GCentral
Message 15 of 15
(1,250 Views)
