FPGA Xilinx Spartan-3A
Does the Labview FPGA driver for the Spartan-3E starter board, also support the other Spartan-3 versions?
I am interested in using the ADC/DAC found on the 3A version of the board for control I/O
Or, are you able to use NI USB hardware on the Spartan-3A board?  Such as the NI USB-6009 ?
(3,716 Views)
Hi KRyan,
The FPGA Module for LabVIEW only supports the Xilinx SPARTAN-3E XUP Starter Kit targets.
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(3,676 Views)
Hi, is this still the case? I also have a Spartan-3A eval kit and I am wondering if I can use LabView with it?
(2,907 Views)
Hi setu_mohta,
Yes, this is still the case. Only the Spartan-3E XUP Starter Kit can be used with LabVIEW FPGA.
Best Regards,
Allison M.
ni.com/support
(2,898 Views)
