Help with using .NET controls
I am trying to load a custom .NET control to use within LabVIEW. When I go to load the .DLL, it gives me the following error: "An error occured while saving the .NET Control [name of the control]." I am following the steps in https://www.ni.com/docs/en-US/bundle/labview/page/creating-net-subpalettes.html. I have built the control with the target framework of .NET 2.0, and registered it in the GAC. I can add things from System.Windows.Forms just fine though, like a button.
Any help is appreciated.
Dillon Welch
(2,736 Views)
Accepted by topic author DWelch123
Why are you following that? Are you actually trying to create your own palette, or simply use the control on a front panel? To use the control create a .NET container on the front panel, then right-click on the container and select "Insert .NET Control".
(2,732 Views)
That helped, thanks!
(2,709 Views)
