FPGA_cRIO build an accurate triangle waveform
my third problem is to build an accurate triangle waveform. Which properties the signal should have, please check out the attached OneNote file "Forum_1_part 3" (in the zip file)
there is a detailed description.
Would be nice if anybody can help me there.
Thank you!
Best regards
Chris
(2,413 Views)
Quick and...
Maybe it gives you an idea, so have fun
Christian
(2,386 Views)
Hello Christian,
i tried your solution out, well it does not look like a triangle but as something similar. Maybe i can use it anyway.
Thx so far!!
(2,377 Views)
