05-24-2012 06:52 PM
my third problem is to build an accurate triangle waveform. Which properties the signal should have, please check out the attached OneNote file "Forum_1_part 3" (in the zip file)
there is a detailed description.
Would be nice if anybody can help me there.
Thank you!
Best regards
Chris
05-30-2012 06:37 AM
Quick and...
Maybe it gives you an idea, so have fun
Christian
05-31-2012 02:16 AM
Hello Christian,
i tried your solution out, well it does not look like a triangle but as something similar. Maybe i can use it anyway.
Thx so far!!
