FPGA compiling- Timing violation Error
Hi all,
I've been around LV for years now, but I'm a complete newbie when it comes to FPGA. I'm working on programming for a 9651 (SOM) using the Dev kit. I'm starting with baby steps, but already tripping up. I have a simple VI that grabs a value from a FIFO and passes it back out to another FIFO. Upon compiling, it's giving a timing violation error and I don't know how to investigate it. Attached is the VI.
So background for the curious... I'm working on the signal processing side of our application. I'm passing data from a pre-recorded TDMS file to a FIFO. I want to send it to the FPGA, process it, and send it back. Eventually this will come from I/O, but for now, I just want to work on the signal processing. Before even starting the work, I figured I'd just make sure I can pass data down and back. Once I get that working, I'll start developing the processing VIs for in between.
Thanks!
(4,002 Views)
Accepted by topic author thutch79
Hi thutch79,
Can you detail the version of LabVIEW you are using and the socketed CLIP implementation you are using for the DevKit IO?
There was a timing violation introduced between LabVIEW 2014 and 2015 because of the way the Xilinx compiler handled the VHDL that supports the second Ethernet port on the SOM.  If you use a socketed CLIP that was generated prior to LabVIEW 2015 (like the shipping example which I believe starts with a CLIP called "DevKit"), then you can get a timing error.  There should be a second example CLIP called DevKit2, I believe, which was regenerated with compatibility for LabVIEW 2015 and later.
This behavior was discussed here: https://decibel.ni.com/content/thread/42711
You can check your socketed CLIP in the project by ensuring you have selected the version called DevKit2 if you have a version of LabVIEW FPGA that is 2015 or newer.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(3,979 Views)
Spot on! That did the trick. Thank you!
(3,924 Views)
