FPGA counter runs negative
I made a simple counter that should increment by 1 when when the digital signal is received. However, when I get to 30,000 counts, it starts running backward in the negatives. Any ideas on why it doesn't continue to run indefinitely? Thank you!
(3,697 Views)
Accepted by JCard
Your datatype is an I16.  It has a range of -32,768 to 32,767.
When you start at 0, it will increment by one.  When you reach 32,767 and add 1, it effectively rolls over.  That bit 15 becomes 1 instead of 0.   For a signed integer, the highest order bit is the sign bit, and 2's complement comes into play.
So it will jump from 32,767 to -32,768 and count UP from there which is towards 0/
How high to you want that number to go?  Try a 32 bit or 64 bit integer.  Do you ever expect to have a negative number?  If not, make it an unsigned integer.  An unsigned 64 bit integer will allow you to go from 0 to about 1.84e19 on a counter.  You don't have any timing functions in your loop so we don't know how fast that loop is running.  But if this was on an FPGA running against a 40 MHz clock, it would take about 14,623 years to roll over.
(3,675 Views)
Accepted by JCard
It's stored in a I16 which can only hold numbers in the range of -32768 to 32767. When it tries to increment from 32767 to 32768 it can't store that high a number so it wraps around to -32768 instead.
It's not really possible to have a integer that continues "indefinitely" since whatever representation you choose will have a max range.
(3,674 Views)
Accepted by JCard
I16 has a  range of +- 32768. Once you go over 32,768 it should start counting back up from -32,767. Use an unsigned 32 for a much larger range of positive numbers. (Right click the number and select "representation")
(3,673 Views)
Lol, I guess we all posted at the same time 😛
(3,668 Views)
Yes, this was the issue...thank you all very much for the help!
(3,664 Views)
