FPGA difference between pack cluster vs unpack cluster
Hello Community,
I used FPGA C API generator to export a header file, but it didn't show any message about the function called
(FPGA VI NAME)_IndiciatorCluster_UnpackCluster
(FPGA VI NAME)_IndiciatorCluster_PackCluster
what would those functions do and how would they be different?
(1,264 Views)
Accepted by cshim31
When a cluster is instantiated on the FPGA it is "packed".  There are no padding bits because alignment doesn't matter on the FPGA.
We choose to represent clusters in C as structs.  Structs are padded and alignment of members can differ on different architectures.
The unpack and pack functions let you convert between the FPGA representation and the C representation.  When reading a cluster indicator from the FPGA you'll read it as the FPGA representation and convert it to a C struct to access the data in it.
C -> packCluster -> FPGA
FPGA -> unpackCluster -> C
(1,210 Views)
