 dalsaffar81
			dalsaffar81
			03-10-2016 06:25 AM
Dear All
I want to program FPGA of the NI-USRP2950R that is makinig QAM modulation using FPGA and not LabView VI in the host.and then take off the host and just power the NI-USRP and use it as transmitter. Is that possible and how i can do it if can?
 JLaenens
			JLaenens
			03-14-2016 09:40 AM
Dear Dalsaffar,
Could you describe a bit more in detail where you would like to have each part of your project being programmed?
Did you have a look into the example project which contains a lot of the functionalities that you have described already. You can find it in LabVIEW by going to File > Create project and selecting the NI-USRP template called NI-USRP Simple Streaming.
Also have a look into the example VI prebuild in LabVIEW under: C:\Program Files (x86)\National Instruments\LabVIEW Version\examples\instr\niUSRP
This folder contains an example of QAM modulation on the host.
Jonas
03-14-2016 11:18 AM
 JLaenens
			JLaenens
			03-23-2016 06:36 AM
Hi Dina,
Unfortunately we do not provide FPGA examples for QAM Modulation. The examples using the RF modulation toolkit are only suitable for the Host system. Programming something similar on the FPGA is a much more complicated task.
Jonas
