FPGA mutlirate low delay sampling with 9237 module
Hello LabVIEW fans
I am trying to develop an FPGA vi that acquires 4 channels on a 9237 module.I would like outputs at 1kHz and 200Hz for different applications on the RT target.
I would like to have low delay so I chose the highest sampling frequency of 50 Khz and I downsample (with very simple averaging respectively on 50 and 250 points).
I wonder if you could comment on the code below
See also the attached vi.
(2,335 Views)
What you mean with "I would like to have low delay"?
Even if you set data acquisition speed 1KHz, you'll send AO data "immideately" after you get a new point.
You need averaging only if AI data has jitting.
(2,277 Views)
Hi Artem.SPb
By "low delay", I mean that I want to avoid the 20 ms delay inherent to module 9237 when you set sampling frequency to minimum, that is 1.6 kHz.
This is why I choose 50 kHz sampling frequency (0.8 ms delay) and I do averaging to downsample at 1 kHz. SO the obtained delay should be 0.8+1=1.8 ms.
(2,271 Views)
I can't understand how did you get your time delays.
50 kHz => 0.02 ms, not 0.8
And if the sample rate is 1.6 kHz, then period = 0.625 ms.
How did you get 20ms?
(2,266 Views)
