problems collecting data with labview from hp 8510c network analyzer
Dera all,
I am trying to operate a very old network analyzer hp8510C. Although its very old there are still some LabVIEW  drivers available for it. So I installed that drivers. However drivers are not functioning properly. What I need to do is make a scan over a frequency range and then record S11, S22, S12 and S21 parameters. There is a vi code for output S parameters. However when I run it I do not get any value but zero for imaginary and reel values of S parameters. Is there anyone who had similar problem and managed to solve it?
(1,207 Views)
Hello
Could you please share the vi example you are using?
__________________________________________
The best way to thank, is to give KUDOS
(1,119 Views)
