FPGA myrio digital signals
Hi! I am new to this LabVIEW World.
In my work I have to take in a digital signal (wit myrio) and then in LabVIEW i need to be able to read the signal and multiply it so i can get the correct values. The problem is that I dont know how to use the DIO so that I can use the multiply numeric. Thanks I hope you understand.
(2,796 Views)
Hi Newbie,
LabVIEW comes with a huge example library to explain most parts of the language.
You can also filter the examples by the supported hardware to find suitable examples.
Have you tried to learn from those examples?
(2,788 Views)
Hi!
Where do I find those libraries you mentioned?
(2,677 Views)
Hi Newbie,
the Example finder can be found in the Help menu (the place where you find all the help in LabVIEW)…
(2,675 Views)
