Flow Meter Amplified Square Wave Measurement using NI 9361
I am purchasing a flow meter that outputs a 12 VDC amplified square wave in order to measure the flow of a fluid. I will be using a NI 9361 module to measure this signal. I want to confirm that this is the correct module to use for this type of signal output. Furthermore, could I use this module to measure other waveforms such as a flow meter with a sinusoidal wave output?
(3,272 Views)
Accepted by topic author MShinn1
Hi MShinn,
Yes, the NI9361 is able to read pulses with upto 24V in differential mode as written in the manual.
The NI9361 expects "digital inputs" (like square waveforms) as written in the manual. A sinusoidal waveform is not digital…
But you can always use your own signal converter (aka comparator circuit) to convert that sinusoidal signal into a digital one. I do that for most of my counter tasks to improve the signal integrity (aka SNR) and to prevent wrong behaviour of counter tasks…
(3,198 Views)
