FPGA oscilloscope to measure power and voltage
I need to create an onscreen oscilloscope, to measure the power and voltage from a detector, using FPGA and LabView. I am attaching the VI. Can someone tell me what I should add to make it an oscilloscope?
(2,546 Views)
What hardware are you using?  I think you should check out the examples.
The code attached will not work as the data out needs to go from the I/O to a DMA-FIFO and then to a GUI VI (two VIs, one on the FPGA and one on the Host).
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,521 Views)
hi,
I am using Ni USB 7856r Xilinx FPGA.
I am attaching the host and target vi I made but I am not able to read anything.
(2,509 Views)
