String to path for Name inside library
Have found a strange behaviour, can you check if it is a bug, or it was a bug in LV2011.
I need to convert input string to a path and check if it is absolute path or relative.
There is a problem when input string is a full name (including library):
library.lvlib:control.ctl
when converted to path it is modified to:
library.lvlib:\control.ctl
Added "\" makes it very wrong and it is absolute path now.
(3,675 Views)
LabVIEW 2018 has the same result library.lvlib:\control.ctl
(3,649 Views)
You can add a backspace before the colon to make it relative. If that helps...
Certified LabVIEW Architect
(3,628 Views)
Hi all,
I agree that this looks like erroneous behavior, but I'm not sure what the developers intended here so I'll need to check. In the meantime, an easy workaround would be to append ".\" to filepaths in the current directory.
Best,
Duncan Waldrop
(3,613 Views)
thols,
it would, but it is still absolute
Are they just checking presence of a colon?
(3,602 Views)
thols,
No, not if you just add a backslash directly before the colon. But if you add something else before the colon (like "\b") then yes.
I meant like: "library.lvlib\:control.ctl".
(3,586 Views)
