FPGA read write not taking boolean array as input
Accepted by topic author Anupama07
You can only use Fixed-Size Arrays in FPGA VIs
Right-click on your array control and select Set Size... to configure it.
https://tmesystems.net/
Message 11 of 12
(551 Views)
Yes.. I fixed the array size and was able to get the Boolean array in the control ... Thanks!!
Message 12 of 12
(538 Views)
