FPGA setpoint value range
Hello guys
i have created a PI control on my fpga.
Is there any labview command to translate this single setpoint into a value range?
i am working on a project using NI cRIO-9035 and Labview 2018
Thank you for your help
(5,625 Views)
Hi Alper,
your question sounded different in the German LabVIEWForum…
How do you want to extend a setpoint to a setpoint range?
Or are you talking about a deadband behaviour?
(5,623 Views)
Hello GerdW
i want to replace the setpoint of my PI-control with a value range.
is this even possible at all?
(5,618 Views)
Nope.
Doesn't make sense IMHO.
(5,613 Views)
And how would you propose to do that mathematically?  The way things work is you choose a set point and then you tune your PID control to the accuracy, ramp rate, and overshoot specifications of your system.
(5,608 Views)
Hi crossrulz,
that's what you got for crossposts: I already proposed a solution to Alper problem in the German board.
And yes, it's nonsense to have a "setpoint range".
Alper simply wants to disable the PID control instead, when the pv is outside a certain range…
(5,593 Views)
