FPGA target to host DMA transfer speed
Dear Guy, my hardware setup is:
1. NI5734
2. pie-7965r
3. pxie-1082
4. pie-8301
So, I used Labview example "High Throughput Streaming - Through Memory", it is stable at 680MB/s.
 What I want to do is using NI5734 acquire signal with 4 channel, sampling rate 80MS/s(external clock), each sample is 16bit(2byte), which mean 4*80M*2 = 640MB/s. Is it possible the task be done by these setup?
Let says that the trigger is 16kHz, each trigger(PXI_trig0) will collect 5000 samples, 16k*5k = 80MS/s. After I collect 5000 samples each time, I will use FIFO to send it to Host. To verify the task, I start collect one channel with 16kHz trigger first, 80M*2 = 160MB/s. Ideally it is far less than it max throughput 640MB/s, it should be work, but It overflow every time. It success unless I used 100Hz trigger for it.
(2,398 Views)
Try increasing depth of FIFOs at host side it will let you store those 5000 samples until you read them.
But try reading FIFOs asap( I mean no delays in FIFO reading loop).
(2,122 Views)
