plot curve
I have to draw N power curves as a function of frequency for each N voltage point. Can someone help me how to display all the curves on the same graph.
I managed to draw the curves for a single tension but for N voltage  I don't know how I can do. Can someone help me?
(2,680 Views)
Hi Faamar,
It depends on exactly which graph you are using, but generally you will be going from a single data set to an array of data sets.
(2,667 Views)
(Please don't use code tags for plain text in posts.)
We need more details. What is the datatype of you data? (dynamic, DBL array (1D, 2D), complex array, etc.). What kind of graph are you using (waveform, chart, xy, etc.). Are the x-values spaced equally or not? etc.
It is typically much easier to help if you would attach a simplified version of your VI with some sample data. Please do so.
(2,663 Views)
Hi faamar,
Yes, there is "someone" who can help: the LabVIEW context help window!
The context help shows how to display more than one plot in a graph…
(2,593 Views)
