FPGA utilization increases on addition of a subdiagram
Hi everyone,
I am using NI PCI 7833R to create my FPGA application. The FPGA application contains multiple single cycle timed loops present in a sequence. When I compiled the code, the FPGA utilization was just 12.5%. However, when I add a piece of code, which just scales the input signal (by multiplication) and writes the input signal to one DAC port, the FPGA utilization just shoots up to 85%. When I compile the above piece of code (writing to DAC) seperately, the utilization is only 2.9%. I do not understand why is this happening. After all I am just writing a signal to a port. Could anybody please help.
Prashant
(2,752 Views)
Can you please post an image of the application highlighting the change? I'm not sure why you are seeing that behavior from the description you gave.
(2,751 Views)
Without seeing the code, I'm guessing you're doing some array operations between the sections.  If you're not careful this can use up a very large chunk of your FPGA resources.  If this is the case we should be able to spot the offending code from a screenshot.
Does it matter though?  Other than trying to be more efficient, which is always good, if your code fits on the FPGA you're done.  Using 85% of the FPGA isn't the same as using 85% of a CPU processor.
--Using LV8.2, 8.6, 2009, 2012--
(2,746 Views)
Attached here is just a part of the entire VI. The subdiagram in part 4 is the culprit. Though I don't see how is that possible. part1 is a shift register, part2 is a dot product, part4 is writing to one port on DAC, part6 is reading from one port of ADC,part7 contains division with divisor being variable, part8 implements the equation x = x + (alpha*y). I have not included the other parts as they are repetitions of part1 and part2.
(2,736 Views)
At first glance, I don't see anything that should cause the increase you are seeing. I have seen situations in the past where this happens and it usually has to do with the compiler optimizing out a good chunk of the code because the results weren't being used by anyone. Perhaps that is happening here, but I can't be sure unless I can get my hands on the actual application.
(2,704 Views)
