Running macro with parameter
I am trying to run a VBA macro on excel with 5 parameters
I have base my design on example found here, but I keep getting an error message
Exception occured in Microsoft Excel:
Impossible d'exécuter la macro 'PVC-A305-05-MACRO-MULTI.xls!MACRO_Multiposition.MACRO_Multiposition'.
Il est possible qu'elle ne soit pas disponible dans ce classeur ou que toutes les macros soient désactivées.
Help Path is xlmain11.chm and context 0 dans TEST_RunMacro.vi
 It basically say : impossibility to run the macro.... it possible than it is not available or every macro are disable...
on the Macro input I am putting "PVC-A305-05-MACRO-MULTI.xls!MACRO_Multiposition.MACRO_Multiposition" am I wrong ? I try several variation of the name and design
I lurk on the site but didnt found any example matching exactly what I was try to do .....
(3,598 Views)
I'd probably guess the latter: macros are disabled. Did you try the Excel macro example that ships with LabVIEW? Does that work? Have you checked to see what your macro security settings are in Excel?
(3,589 Views)
I manage to run the Macro I was Wrong about the name of the macro I add only to write the last part (xxx!yyy.zzz => zzz)
I will post a complete VI later
(3,583 Views)
