FPGA
Hi there,
 I am currently using NI Myri-1900 board. I am trying to run an example of "image processing with vision Assistant" that i got from the Help>> Find examples >> Vision FPGA. Can anyone tell me how can i managed to run this demonstration program ?
(3,952 Views)
What error are you running into?
I don't have LabVIEW in front of me but you cannot acquire images from the FPGA on myrio, only process, so make sure you remove thay functionality if it is there. I would also be interested in what you want to do because image analysis on the FPGA does not necessarily improve performance and usually adds a lot of complexity.
(3,900 Views)
Hi there, I tried plug in my C920 HD Pro Webcam onto the myrio USB, and I open the demo project trying to run it. However, it showed error that the fpga target VI  need to be compiled first, but i failed to compile it. The errors are as in the attachment.
I am trying to use myRio FPGA to do image processing such as template matching function in OpenCV in hoping that the processing speed can be better than a processor and raspberry pie.
(3,889 Views)
I am still new to graphical programming and currently still finding tutorials to access to the image processing in FPGA.
(3,881 Views)
Hello Ada678,
check out this link: http://digital.ni.com/public.nsf/allkb/B77CEB8067558F6F86257203007F1E91?OpenDocument
I think it could help you.
Kind regards.
(3,805 Views)
