FPS issue GigE IMAQdx Grab and Save to AVI
I have been trying to get 30fps with a Grab and Save to AVI .vi with a Greypoint camera over GigE. I have tried both with the LabView example and with the ring buffer example (https://decibel.ni.com/content/docs/DOC-39157) & (https://decibel.ni.com/content/docs/DOC-36471).  I am using MJPEG to compress the file in AVI Create.  I have used both AVI and AVI2 vi.  Using the example code to read the buffer number I can see that I am acquiring at about 45fps and processing at an inconsistent 20 fps.  No matter what I do I can’t increase the fps.  I believe that with the Grab and Save, the frames are getting over written before they get a chance to be processed.  So using a producer consumer loop should fix that, but it doesn't increase the fps.  I know that IMAQ produces a pointer and is not actually queueing the actual image, but I found a code that puts the whole image into the queue, and that didn't seem to help either.  Appreciate any help, I'm stuck.
(3,589 Views)
-What camera you are using exactly?
-What is the maximum fps of camera?
-What is the resolution you are trying to acquire?
-Can you post what you tried?Is that the same example?
-So only acquiring you are able to? If not i would first do that experiment to ensure you can acquire at the frame rate you require and then go to processing section.
uday
(3,584 Views)
Camera data sheet is attached.  It is capable of 120fps.  I will be cropping the image but for now would just like to be able to record at 30fps for full resolution.  I know that I am aquiring at 45 fps based on IMAQdx buffer number example which I will attach when I get back to the lab in an hour.
(3,581 Views)
You sent USB3 camera spec and your question is about GigE. Please clarify on which camera you are using.
uday
(3,575 Views)
It is USB I was incorrect
(3,573 Views)
This is the code that I modified from the original example Save to AVI example built into Labview.  I added the code from Grab and Detect lost buffers.  This allows me to see the see the acquired frame rate and the processed frame rate.  I added the additional code CirImBuf which supposedly takes the images from IMAQ Create Vi and saves them to a circular buffer.  This should be saving the images directly as opposed to just saving the pointer to a buffer.  Adding it had no change on the fps processed over just having IMAQ create in line directly.
(3,553 Views)
This is the code that I used to try and add a ring buffer to the code.  I can’t use the code to get the acquired and processed frame rate anymore but I know it’s less than 30 because I was recording a stop watch.  I modified the code by first removing the excess processing I didn’t need.  I then added the cirimbuf instead of the for loop.  Neither would increase the fps noticeably
(3,551 Views)
