User Control Boolean with trigger interception
Hi all,
I would like to use Labview FPGA to do the following function:
The digital output port serves two purposes. When there is a trigger input, the port output a "true" signal. When there is no trigger, the port is idle, BUT it can be controlled by the user by a boolean switch in the front panel.
I tried using two while loops, one contains a boolean control connecting to the DIO, with another while loop detecting the trigger and a constant "true" is connected to the same DIO when trigger is present. However, only the user control boolean works fine, but when a trigger is present, it doesn't repsonse...
Could anyone please kindly comment on my case?
Best,
Matt
(3,130 Views)
1. There is nothing in your description that tells me you cannot use a single loop.  It will save resources and actually make things a little simpler.
2. You need to OR your two conditions together.
(3,096 Views)
