FSK modulation
    how can i edit the example of FSK modulation i downloaded from NI.com to show modulation waveform graph instead of only IQ data and Spectral analysis graph??
(5,063 Views)
Hi Serina,
see the attached example please. I hope this helps.
Mike
(5,049 Views)
Hi Mike,
           I cannot run the program you send me and the VIs added by you is another language, which is different from mine (is not english). I think because is different version so i could not run it.. Smiley Happy
(5,042 Views)
Hi Serina,
which LV version do you use? The different language should be no problem.
Mike
(5,039 Views)
I can run the program already but i still don't understand the graph and get the desired waveform i want. It is just a high curve that is barely visible by the top of the graph.
can you help me or explain to me? Thanks!
(5,032 Views)
Hai serina,
Try reducing the amplitude level in ur graph.
Hope this helps.
Mathan
(5,027 Views)
actually is already very low is between 0.99 -1 so i am very bewildered too..Smiley Indifferent
(5,020 Views)
