vista driver for USB GPIB HS
I have downloaded vista driver for USB GPIB HS and still when I add the cable it says it cannot find the driver for the USB-GPIB-HS.
(3,091 Views)
Hello again, Mr. O’Brien - please note that I was careful to spell you name correctly Robot wink
My name is Richard, and I spoke to you briefly on the phone earlier. As I mentioned, Labview 8.2 was the first version of LV which officially supported Windows Vista. A patch update (8.2.1) added further VISTA support, and ironed out a few bugs. Therefore 8.2.1 is the oldest version of LabView I would recommend for use with Vista.
Rich
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,065 Views)
Furthermore, I have identified two web articles which may be of interest to you.
1.       Explains which GPIB driver software you will require to run your GPIB-USB-HS with VISTA
http://joule.ni.com/nidu/cds/view/p/id/335/lang/en2
2.       Discusses the removal of unsupported NI software from Windows, prior to the installation of your new software. https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
I hope this if of some use to you. Best wishes,
Rich Roberts
(3,063 Views)
