FTDI settings
And please ignore that manual. It only pertains to the other driver but since you wanted to use VISA, got removed, remember?
Message 11 of 15
(1,211 Views)
"Welding"... well I used the translate... and I saw also on google...welding tin foil... bytheway I connected the RXD with the TXD 🙂
About the CTS and RTS what I want to learn is how to set  CTS at "1" for a certain period of time and in the same time have RTS at 0.
Message 12 of 15
(1,210 Views)
Ok Dennis.
I gave a look at the property but probably I'm doing a mistake somewhere but I'm not able to access to the RTS/CTS. I went here:
Serial Settings-->Modem Line settings -->Line CTS state (for example) but It is available only in the read status I can't change it into the write.
Message 13 of 15
(1,208 Views)
You are not supposed to be able to change to write. It's a handshake line and is set by the remote instrument. You don't set any of the handshake lines manually in a typical communication session. That is why this whole thread seems a waste of time.
Message 14 of 15
(1,205 Views)
yep I checked on the NI guide and seems that I'm only able to change the RTS and DTS status.
Thank you.
Message 15 of 15
(1,203 Views)
