03-20-2008 06:09 AM
"I've succeeded to write data over synchronous mode with labview interface.
I'm trying to use the MPSSE mode to communicate with SPI, but I don't understand the commands I have to send before sending data."
doesn't tell me very much!! ![]()
If you post the code that you have written so far and explain what you are trying to do in a bit more detail then i can help (perhaps spot a problem in your code). I need more information.
Phil
03-21-2008 03:57 AM
03-21-2008 09:55 AM
05-28-2008 04:01 PM
05-29-2008 03:33 AM
Hi brian,
before SPI_Read, you have to call SPI_InitDevice, this function enables the MPSSE mode required to communicate with SPI bus.
so it goes:
SPI_GetDeviceNameLocID - SPI_OpenEx - SPI_InitDevice - SPI_Read - SPI_Close
you can find help at http://www.ftdichip.com/Projects/MPSSE/FTCSPI.htm , there is some code examples.
can you tell us wich software you're using? maybe I can help you more then.
Adnane.
05-29-2008 09:40 AM
05-29-2008 12:05 PM
06-02-2008 06:59 PM
Hi Brian,
I've tried to investigate your question: "A question I have is why is there a minimum of 2 bits for the control stuff. I have a device that simply starts putting data on the wire when the CS is low and the clock is running. Is the writing of the control bits going to impact this?" I don't have access to the dll code, so I can't really look into it further. It sounds like a setup feature in the dll itself though.
You might want to direct your question to the FTDI Support in order to get the answer you want.
Kevin Stuart
06-03-2008 10:55 AM
06-04-2008 02:09 PM
Hi Brian,
I can try to help you with the LabVIEW side of your project, but the specifics in communicating with the MPSSE processor on the FT2232 is a little bit out of my league. Perhaps someone who has read your posting can give you some more details on how to do this successfully.
Kevin S.
