FTP copied files
Hello all,
I'm using self made VIs based on internet toolkit (FTP) to copy files and folders from a RT PXI to a conventional PC.
To check if the process is correct, after copying a file, I check the original file size (with "FTP get file info.vi") and the copied file size (with "File Info").
Can someone tell me why .ini files (original and copied) have exactly the same size, and .dat files are always a little bit bigger when copied to a WinPC ?? :S
Is it because of a difference between RT OS and Windows ??
Thanks in advance for any info.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,104 Views)
hi there
i'm not familiar with the internet toolkit but for me it sounds like the .ini files are transfered as binaries and the .dat files as text. that would explain the higher number of bytes of the binary .dat files on a windows platform. when transfered as text all bytes "\n" (x0A) are replaced by "\r\n" (x0D x0A)
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,101 Views)
Perfect guess Chris ! Thanks a lot !
When I enable the "bin" option on the FTP vi, size result to be exactly the same !
Epictetus
Antoine Chalons
(3,094 Views)
