How to close a VI
Hey all,
My name is Sarang Jaiswal. I want to close the VI as soon as I press EXIT button . I mean the Vi should disappear from the screen as soon as I press this EXIT button.
I tried out using the Property node but all in vain. Could you all please help me in this
Thank you
Sarang Dhananjay Jaiswal
Satyam Development Center, Banglore, INDIA
(4,248 Views)
HI Sarang Jaiswal
see attched png
chow xseadog
(4,246 Views)
Hi Again
if you only want the vi to disappear after use but remain in memory then
Customise  in Window Appearances in VI properties
chow
 xseadog
(4,246 Views)
Hey,
Thanks a lot for the wonderful solution. Its working for a vi. But still has not solved my problem. I will explain it ....
I have 2 vi's
1. Main.vi
2.Sub.vi
I am calling Sub.vi from Main.vi by using the property node. Now when I press EXIT button in the sub.vi  my  Main.vi also closes, but I want to retain my Main.vi on screen
path ------>    VI        ---------->    VI
              FP.Open                 Run VI
I hope you got my problem.
(4,203 Views)
Hey,
I have 2 vi's
1. Main.vi
2.Sub.vi
              FP.Open                 Run VI
                                             Wait
(4,204 Views)
If this is what you want to do,  try what @seadog is suggesting.  However, the option "close afterwards if originally closed" only works if the subvi is *closed* when you run main.vi.
Once sub.vi has completed running, it will return and continue to run main.vi, where you should close the vi to remove from memory.
(4,181 Views)
