Facing issue in labview
Hello Sir,
I want to use I2C Write/Read and SMBVS for different voltage supply ,I referred the NI manual for the application mentioned but repeatedly I am getting error 301740 The I2c master failed to seize the bus. Sir guide me to resolve the issue.
Message 1 of 17
(4,862 Views)
This is not really a LabVIEW question, but a hardware question.
(I moved it here for now because it definitely does not belong into the feedback forum, but it could probably be moved again once we know a little more about the problem.)
Message 2 of 17
(4,844 Views)
Thank you for the  response I will ask in hardware section.
Message 3 of 17
(4,840 Views)
Hello Sir,
I want to use I2C write and I2C Read for different voltage supply (low and high) in NI LABVIEW 2017 SP1.I am using NI USB 8451. I referred the NI manual for read and write simulation file and had taken the example files General I2C Read/Write but facing the error 301740 The I2C master failed to seize the bus. Please guide me to proceed.
The error message screenshot is being attached here.
Message 4 of 17
(4,844 Views)
just a quick note:
please don't attach 12MB .rtf (i didn't open it, so maybe it is an image .... normally it is an extension for rich text document)
attach a small image (either .jpg or .png) if you want people to look at your problem.
if you have code, attach the .vi
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 5 of 17
(4,828 Views)
Error -301740 occurred at NI-845x I2C Write.vi:4470001
Message 6 of 17
(4,826 Views)
did you actually search for your problem?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFlTSAU
Message 7 of 17
(4,823 Views)
Seen that error plenty of times.  Always due to something on the bus holding the line low.  If a chip you can communicate with is not properly powered, that can also drag a bus line down.
Message 8 of 17
(4,800 Views)
Hello Sir,
Yes sir I searched for the problem, I checked all the parameters like wire length and  pull up resister which is already there but cant understand where I am going wrong.
Message 9 of 17
(4,766 Views)
Hello Sir,
I checked the power supply the Led is blinking green which means status is on I understood, but what else I need to checked please tell me.
Message 10 of 17
(4,763 Views)
