Facing issue in labview
Have you probed the data and clock lines to make sure they are high when nothing is being transmitted?  Use an oscilloscope to look at the signals during a transmission as well to see if perhaps the slew rate is too slow.
Message 11 of 17
(1,055 Views)
I tried to connect pull up resistor and connect it to the target device. But still getting same error.
Sir in general example EPROM address is there but in our application we are not using  EPROM  so is there issue( Error -301740 occurred at NI-845x_1800 I2C Write.vi:4470002) because of this? Sir guide me regarding this please.
Message 12 of 17
(1,036 Views)
You are trying to communicate with something that is not there?  I would expect a different error if that was the case.
Again, your error -301740 implies that you have a bus issue, not anything in software.
Message 13 of 17
(1,033 Views)
Sir Thank you for the response, it will be great help if I get to know how to rectify bus issue.
Message 14 of 17
(1,012 Views)
Start probing with an Oscilloscope.  Is something dragging the bus lines low?  Start removing devices from the bus until the pull-up works.
Message 15 of 17
(1,002 Views)
Hello Sir,
I want to make use of  I2C NI USB 845X_  hardware in Labview .I referred the file being attached here because I want to write the data and then read the data, I am facing error that master failed to seize the bus. Sir can you guide me what modification I should do.
Message 16 of 17
(987 Views)
Do you have access to an oscilloscope? Did you try monitoring the bus lines with an oscilloscope like crossrulz suggested?
Message 17 of 17
(972 Views)
