Fail to open Serial Port
@Martin_Henz
I'm far alway from my customer. I asked my service enginner to run this VI after forcing close the C++ software.
This VI works, no error is present.
Message 21 of 25
(1,440 Views)
Accepted by changelopnur
@changelopnur wrote:
@Martin_Henz
If this works for you, you can download and install the complete library  from https://www.mhst.de/upload/47519452-lvserial-1-2-13-32.zip
Message 22 of 25
(1,425 Views)
It's always frustrating when the customer asks you to solve their problem - but you have no control over the problem!
Bill
CLD
(Mid-Level minion.)
Message 23 of 25
(1,404 Views)
@Martin_Henz,
Thank you very much.The library works.
I just replace serial functions with the VIs of library.
All these VI interfaces are the same with the function of LabVIEW2014.
I want to know who developed this library, the 3nd partner?
Because I find all the functions between LabVIEW2014 and the library version LabVIEW2018 are the same.
Thank you.
Message 24 of 25
(1,376 Views)
@Martin_Henz,
I started development for this library long time ago, At this time VISA had lot of ugly bugs (and slow) for the serial port (VISA has still has some undesirable behavior). The library has some additional features but in general it can be used as a replacement. Help text is avaiable though the labview context help (for nearly all VIs and their controls). It is written in plain C code, the source code is also available and last but not least a 64 bit version.
The library uses only the asynchronious mode, because I see no benefit from synchronious mode.
Message 25 of 25
(1,370 Views)
