Failing to send email via LabVIEW, Error 1172
HI,
It's my first time attempting to send an email via LabVIEW.
I tried different example and built my own but error 1172 keep coming up.
Does anybody have an idea why? I've looked the forum and internet but I didn't find the solution.
I'm using labview 2017
Thanks in advance for all your help.
(3,322 Views)
1172 is the only error you will ever get from using .NET nodes in LabVIEW.  You always have to look at the text.
I don't speak French, but it looks like it's saying it can't connect to the server in question.  If so, that's not a "LabVIEW" problem, it's either a problem with your PC, the mail server, or the connection between the two.
(3,295 Views)
Accepted by JCMathieu97
found the other day a working solution from Hardik Asawa,
https://forums.ni.com/t5/LabVIEW/how-to-send-an-email-from-a-VI/td-p/983191/page/4
(3,216 Views)
