Failure: "drawmgr.cpp", line 3443, LV 6.1
Hi!
This is another failure that I got lately. I think it also has something with the "3D Surface Graph" that I already posted a question about (in fact, just yesterday). My impression is that cw 3D Surface Graph has some fatalities in it that cause the whole application work unstably.
Miro
(2,805 Views)
Miro;
That type of error is an internal error. You can check (i.e. search) for documented errors here:
http://www.ni.com/support/failure/
Apparently, your specific error is not documented. Look also at the following NI document:
LabVIEW Internal Errors.
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
(2,805 Views)
Hello Miro,
Thank you for contacting National Instruments.
The following link leads to a Knowledge Base concerning a similar error. It lists four possible work arounds.
http://digital.ni.com/public.nsf/websearch/16CF1334D094A4F6C1256BE30074B9FE?OpenDocument
If these do not solve the problem, make sure that you are using the current Run Time Engine for your version of LabVIEW.
I hope this helps,
Sean C.
(2,805 Views)
Hi, Sean,
I will go to check out what the Knowledge Base has about the similar error. However, this error happened locally in LabVIEW, i.e. without me using the Run-time Engine (which doesn't mean it wouldn't happen with the Run-time Engine, too).
The problem with the use of the Run-time Engine that I reported was "window.cpp" kind of error (I posted it on 2/9/04).
Miro
(2,805 Views)
