Failures in image.c???
Thanks for your replies once again,
unfortunately the company I work for is still deciding whether or not to
give me a full development version of LabView, so I still dont have access
to the picture tool kit, as at the moment I am limited to the basic package
(and yes that is something I'm working to change). As far as I can see, picture
listboxes are the only way I can build animations, and they cause LabView
to crash. If I get access to a development license, I will try out your ideas
and post again, but at the moment I still hope (somehow) to get the picture
listbox to work.
Ben
Message 12 of 13
(835 Views)
Other tricks (might show flicker)
Make an array of your picture ring; show only one element;set the array to
the sequence 0,1,2,3,4... To animate, set the array attribute node "Index
Value". Might not solve the problem but worth a try...
Paste your pict in booleans packed at the same position on screen and make
them visible/invisible in sequence.
Best luck...
Jean-Pierre Drolet
"Ben" a écrit dans le message news:
39dddcea@newsgroups.ni.com...
> to the p
package
ideas
> listbox to work.
> Ben
Message 13 of 13
(835 Views)
I have heard of a similar pict ring problem that occurs on Win 9? machine
and works fine on a Win NT machine. Might be OS related... or the machine.
However as a workaround I would try some other LV technique to display your
animation, before trying ActiveX.
What about a picture control? You can convert your images to picture control
data type and display them in a picture control.
Best luck.
Jean-Pierre Drolet
39dd8197@newsgroups.ni.com...
> That is the advice NI gave me,
> but it didn't make much difference unfortunately, it simply took longer
> to crash. And to be honest, I can't see it being a problem with the
graphics
> drive
rs really, I've tried it on 3 different machines with an ATi Rage
Light
> 8Mb graphics card, a Matrox MGA-100, and an Nvidia TNT2 M64. If it crashes
> with all 3, then surely it can't be the graphics drivers?
> Ben
Message 11 of 13
(835 Views)
