False constant wired to Continue if True
This may be a question that has a painfully simple answer, but I can't seem to make heads or tails out if it.  What is the value of writing a VI that contains a while loop that uses the Continue if True terminal and then wiring a False constant to it.  I have seen this in several places in both NI example code and in some of their function VI's, most recently where I am using the PID functions.  If the loop is guaranteed to iterate only once, then why use the loop structure at all?  My feeling is that it is use for VI memory allocation or creating references to a VI that is expected to run more than once in the calling VI, but that is as far as I can guess about the value of this type of programming architecture.
Eric
(3,646 Views)
Because the values stored in unitialized shift register.
For example  look here: Basic Functional Global Variable Example
Andrey.
(3,639 Views)
Eric,
this is a special architecture for VIs to contain data. This architecture has several names:
Lab-2-style Variable
Action Engine
You can find lots of information on this if looking around on ni.com and even in this forum.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,638 Views)
Accepted by Gravy_Train
There is a nice description in the LabVIEW wiki entry Functional Global variable
(3,621 Views)
I would never wire a false constant to Continue if True.
(I always wire a true constant to Stop if True! Smiley Very Happy )
Jim
(3,573 Views)
It depends from the optimistic or pessimistic principle...
"...To the optimist, the glass is half full.
To the pessimist, the glass is half empty.
To the architect, the glass is not big enough..."
Andrey.
(3,568 Views)
