Fan Control Using LabView
Dear LabVIEW Experts,
I'm trying to control my fan with labview, but currently have no success. I have tried using the LabVIEW solid state relay but no luck with that. https://forums.ni.com/t5/Example-Code/Turn-on-a-DC-Computer-Fan-using-a-Solid-State-Relay-myDAQ-and/...
I have attached my fan spec. Please help me with this problem. Is there a better way to connect an fan with labVIEW.
Materials:
Dual Mos Fet Trigger Switch Drive Module PWM Regulator Control
Power Supply 12V
Resistor
Transistor: https://www.google.com/search?q=2n222&sxsrf=ACYBGNROPsQ6lL7jQGpPkUffXoSehWYfnw:1583202573471&source=...
Diode
(4,350 Views)
How can we help?
You haven't shown us anything you've done.
We can't see or touch your hardware.
(4,321 Views)
Accepted by topic author Wtariq67!
Its always better to share the piece of code which you have tried and failed, which will make others to guide you.
Hope the shared Link clearly explains on technical details.
Not sure where you got stuck, will be better if you can explain bit clear.
First make sure you have made all the  hardware connections in proper, Use NI MAX to Switch ON and OFF (DO). Once you are able to Control your Fan using NI MAX then you are good to Start your Programming.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,294 Views)
