Fatal Error: Failed to open handle for AFLVCG61.msi
Fatal error occured while installing Device Drivers CD. I have no clue Help.
Message says Failed to open the handle for D:\components\max\AFLVCG61.msi.
And, the details says:
K:\NIInstallers\dev\1.1.2\src\UberInstaller\IniFileInfo.cpp(968): IInstallerError 11002
Fatal Error. Failed to open handle for D:\components\max\AFLVCG61.msi.
Failed to open database handle for D:\components\max\AFLVCG61.msi.
Msi Error: 110
Error Record:
Exception code: E06D7363 ()
Fault address: 7C59BBF3 0001:0002ABF3 C:\WINNT\system32\KERNEL32.DLL
Registers:
EAX:00FEF1D8
EBX:0041E507
ECX:00000000
EDX:0000000C
ESI:00FEF268
EDI:00FEF1F8
CS:EIP:001B7C59BBF3
SS:ESP:002300FEF1D0 EBP:00FEF228
DS:0023 ES:0023 FS:003B GS:0000
Flags:00000206
Stack Trace
Address Frame LogicalAddr Module SymbolName + Offset
7C59BBF3 00FEF228 0001:0002ABF3 C:\WINNT\system32\KERNEL32.DLL RaiseException + 86
004C3160 00FEF268 0001:000C2160 D:\setup.exe
0041E5CC 00FEFA5C 0001:0001D5CC D:\setup.exe
0044DA59 00FEFB40 0001:0004CA59 D:\setup.exe
0043EAE0 00FEFB84 0001:0003DAE0 D:\setup.exe
004402BF 00FEFCDC 0001:0003F2BF D:\setup.exe
00463C4B 00FEFD84 0001:00062C4B D:\setup.exe
00463D46 00FEFDA8 0001:00062D46 D:\setup.exe
0046B4A1 00FEFDF0 0001:0006A4A1 D:\setup.exe
0046B55E 00FEFF18 0001:0006A55E D:\setup.exe
004EB185 00FEFF80 0001:000EA185 D:\setup.exe
004C8EED 00FEFFB4 0001:000C7EED D:\setup.exe
7C57B388 00FEFFEC 0001:0000A388 C:\WINNT\system32\KERNEL32.DLL lstrcmpiW + 183
(2,973 Views)
Hi LegalEngineer-
Which operating system are you using? It seems like either you got a bad Driver CD disk or that your Windows Installer might need to be updated.
You can find updated driver downloads for all NI hardware at Drivers and Updates at ni.com. I generally prefer this method because it avoids installing unnecessary software and also ensures that all drivers are up to date.
Tom W
(2,962 Views)
Operating System is Win2K.
After I uninstalled all NI software, I installed the drivers and other software without error.
I am still not sure what caused the error but now the problem is gone.
(2,953 Views)
