can we do with a 16 pin terminal base for fp-tc-120?
i got a thermocouple module for my project. The terminal base contains only 16 pins. Is there ne solution for this or shud we get a 32 pin terminal base ?
(2,344 Views)
The 16 pin terminal base is the FP-TB-3. It is specifically designed for use with the FP-TC-120. The FP-TC-120 requires pins 1-16 for input channels 0-7. Pins 17-32 are not required. The FP-TC-120 will work with any of the FP-TB-X terminal bases.
Aaron
LabVIEW Champion, CLA, CPI
(2,339 Views)
