Making executables with Labview 7.1.1 and Vision 7.1.1
I'm having trouble getting executables to run on target machines.
My Setup:
Ni Vision Development Module 7.1.1
Labview Base Development System 7.1.1
Labview Application Builder
Imaq Vision Deployment Engine
I would like to make an executable which runs on a target machine and which gives the "The is a demo version" warning.
The reason for this is that we want to be able to give these executables to customers, but we don't want to buy extra licenses for them unless they want to buy the software.
If I compile the executable with installer and I don't include the vision71rte.exe, the executable won't run.
If I do incluse it, the executable will run, but the target machine will also be registered as if having a valid vision license.
How can I make an executable which can run on a target machine which does not license the machine?
thanks in advance.
Arend Hiddema
(2,877 Views)
In order to run your executable with Vision on one target PC you will need to have one run time license. this includes any evaluation copy of your application.
Please contact your local National Instruments Sales Office to inquire to the possibilities for distributing you application as a evaluation including a run-time engine for vision.
Met vriendelijke groet / Kind regards,
Karsten
(2,838 Views)
