Fatal Internal Error "obiheap.cpp", line 579
I want to compare my broken programs.
The problem I meet with is that some of my programs accomplished months before can not be opened and messages are given: Fatal Internal Error: “objheap.cpp”, line 579 or Fatal Internal Error: “ memory.cpp”, line 1704.
I use LabVIEW7.1 with PCI-6221.
Any addvice is apperiated.
Three broken programs are attached.
(2,709 Views)
I also cannot open your a and b vi but c looks normal.
except that you use a bit wild wiring scheme ( try to connect with straight wires as much as possible)
( and take the error wire as a baseline )
I get the same obj heap problems, what operating system are you using with which filesystem?
greetings from the Netherlands
(2,700 Views)
