insert into array
Hi all,
I got a problem inserting data into an existing array. Pls refer to the jpg file, how could I insert an array into the 'red color' cell as Insert Into Array function only allow me to specify either row or column at one time. Pls help.. thanks
(3,543 Views)
For an existing 2D array, you would need to use the Replace Array Subset function to replace the contents of the array at that row/index.  Insert Into Array will only insert rows or columns at a time when using with a 2D array (as you already figured out).
-D
(3,537 Views)
Hi Darren
I've tried the Replace Array Subset but with no success... Could you pls show me an example..? Let's say I have 2 1D of array. How can I place both of it according to my specified location. ?
(3,537 Views)
Sorry, I skimmed the first post too fast and didn't realize you were trying to insert an array at that point.  I did a search on the forums and found a thread that I contributed to a while back that talks about this subject (and includes a sample VI):
http://forums.ni.com/ni/board/message?board.id=170&message.id=174709
Hope this helps,
-D
(3,489 Views)
